INSTALAR Y CONFIGURAR OpenMPTCProuter | Multiples conexiones de Internet con OpenWRT | Tutorial
OpenMPTCProuter utiliza MultiPath TCP (MPTCP) para agregar realmente múltiples conexiones de Internet con OpenWrt. La imagen se puede instalar en x86, x86_64 con UEFI, Raspberry PI 2B/3B/3B+/4B, Linksys WRT3200ACM/WRT32X, Teltonika RUTX12, NanoPi, Banana PI BPI-R2, Gl.inet, Promox, NetGear, QNAP, SHDSL, Ant Router ZBT, Starbox CM520-79F, Ubiquiti Edgerouter, Virtual Machine con Virtual box y VMWARE.
Las caracteristicas fundamentales son:
Aggregation : Unir (Bonding) conexiones para agregar realmente el ancho de banda de hasta 8 conexiones a Internet con diferentes características (Fibra, ADSL, VDSL, 4G, 5G, Satelital StarLink, HFC entre otros).
Failover: Siempre activo con conexión y conmutación por error del servidor
Security: Todos los datos entre el enrutador y la parte del servidor están encriptados de manera predeterminada y pueden ofuscarse.
Un servidor VPS con Debian 9/10/11/12 es requerido
LINKS IMPORTANTES
https://55860.com/index.php/knowledgeba ... ptcprouter
https://github.com/Ysurac/openmptcprouter/wiki
https://55860.com/
https://zbtwifi.com/productinfo/1049173.html
https://openmptcprouter.world.taobao.com/
https://item.taobao.com/item.htm?spm=a2 ... R2Gbd91uLf
https://www.openmptcprouter.com/download
https://snapshots.openmptcprouter.com/6 ... k/filogic/
flint2
https://github.com/Ysurac/openmptcprout ... te-the-VPS
https://github.com/Ysurac/openmptcprouter/issues/3327
https://github.com/Ysurac/openmptcprout ... /Snapshots
https://github.com/Ysurac/openmptcprout ... er-install
https://github.com/Ysurac/openmptcprout ... figuration
https://github.com/Ysurac/openmptcprout ... sions/2480
https://multipath-tcp.org/pmwiki.php
https://forums.raspberrypi.com/viewtopic.php?t=61401
https://www.tutos-informatique.com/adsl-4g-agregation/
https://www.uiblog.it/2025/01/congestio ... tcprouter/
COMANDOS
curl ifconfig.io
ifconfig eth0 192.168.10.155
route add default gw 192.168.10.1 eth0
uci set network.lan.ipaddr='your-static-ip-address' && uci commit && reboot
LABORATORIO
aggregate multiple internet connections using Multipath TCP ,MPTCP,OPENWRT,NETWORKING,DUAL WAN LOAD BALANCING,Balanceo de Carga,Faiover conexion,aggregation,ISP ,WAN type,encrypt multiple internet connections ,IP Publica,Firmware Tp-Link,Aggregation VPN,Virtual Private Network,red privada virtual,Flint 2,enlace VPN agregado para el acceso a Internet,GLINET,GL-INET,CONEXION ESTABLE de INTERNET,Proxy,OpenVPN,Wireguard,Linux Kernel,Ubuntu,Amazon,Server VPS,OVH,Contabo,Cloud Provider,Kernel MultiPath TCP,How to Install MPTCP,Routing ,Linode,Hetzner,Digital Ocean,Configure MPTCP,ysurac,INTERNET RAPIDO ,openmptcp,Faster Internet,Internet Bonding,VPN BONDING and MultiPath,Multi-link VPN ,MLVPN,Servidor DNS,OMR,Glorytun UDP,security,reliability,net neutrality,Router node management,configurar un nodo de salida,exit node,Exit Node Settings
