Simple Smart IPTV (SS IPTV) for LG and Samsung TV
I got it from LG Content very easy to use but it works on Samsung TV see how to:
The app works on TVs of E Series and higher
Install SS IPTV on Samsung Smart TVs of E series
Press SMART TV button on your RC.
Press red (A) button to enter in account
Create account with login develop and any 6-digit pass
Press red (A) button again end enter, using just created develop account
Press on your RC blue (B) button if you have D Series TV or Tools button if you have E Series TV
Select Settings-> Development -> Setting Server IP
In menu appeared enter 91.122.100.196
Chooske User Application Synchronization.
SS IPTV should appear in apps' list when the installation is finished
Install SS IPTV on Samsung Smart TVs of F Series
Press MENU button (for TVs with touch RC - press MORE, then select MENU).
Go to section Smart Features, Samsung Account.
Select Enter.
In e-mail field enter develop, the field Password leave blank (it's necessary to enter pass sso1029dev! for some models).
Press SMART TV button, scroll to Apps and select More Apps.
Select Options at the top right, then select IP Setting.
Enter IP 91.122.100.196
Return to the Options menu end press Start App Sync.
Install SS IPTV on Samsung Smart TVs of H Series
Select Enter.
In e-mail field enter develop, the field Password leave blank.
On any of the installed apps, hold the Enter button down for few seconds
In menu appeared select IP Setting
Enter context menu again (long press on any app) and select Start App Sync.
Install SS IPTV on Samsung Smart TVs of J Series
Format USB Flash Drive into FAT32
Create on your USB Flash Drive the folder named userwidget
Download the app's archive, using the button below and copy it (without extracting) into created folder.
Insert USB Flash Drive into TV's USB-port, installation process will start automatically
Launch SS IPTV using USB Flash Drive
This way may not work for some devices
Create in the root of USB Flash Drive the folder named ssiptv
Extract archive in created folder
Turn the TV on and insert USB Flash Drive in it
Launch Smart HUB. SS IPTV should appear at the end of app's list (or in More Apps section)
archivo para Samsung Smart Tv
http://ss-iptv.com/files/samsung.zip
La aplicación funciona en televisores de la serie E y superiores
Traducción
Instale SS IPTV en los televisores inteligentes Samsung de la serie E
Presione el botón SMART TV en su RC.
Presione el botón rojo (A) para ingresar
Crear cuenta con inicio de sesión y cualquier pase de 6 dígitos
Presione el botón rojo (A) de nuevo termine la entrada, usando la cuenta desarrollada creada
Presione en su botón azul RC (B) si tiene el botón D Series TV o Herramientas si tiene TV de serie E
Seleccione Configuración-> Desarrollo -> Configuración de IP del servidor
En el menú aparece ingrese 91.122.100.196
Sincronización de aplicaciones de usuario de Chooske.
SS IPTV debería aparecer en la lista de aplicaciones cuando se complete la instalación
Instale SS IPTV en los televisores inteligentes Samsung de la serie F
Presione el botón MENU (para los televisores con el toque RC - presione MORE, luego seleccione MENU).
Vaya a la sección Funciones inteligentes, cuenta de Samsung.
Seleccione Enter.
En el campo e-mail introduzca desarrollar, el campo Contraseña dejar en blanco (es necesario ingresar el pase sso1029dev! Para algunos modelos).
Presione el botón SMART TV, vaya a Aplicaciones y seleccione Más aplicaciones.
Seleccione Opciones en la parte superior derecha, luego seleccione Configuración IP.
Ingrese IP 91.122.100.196
Vuelva al menú Opciones y presione Inicio de la sincronización de aplicaciones.
Instale SS IPTV en los televisores inteligentes Samsung de la serie H
Seleccione Enter.
En el campo e-mail enter develop, el campo Password leave blank.
En cualquiera de las aplicaciones instaladas, mantenga presionado el botón Enter durante unos segundos
En el menú aparece seleccionar IP Setting
Ingresa de nuevo al menú contextual (presiona larga en cualquier aplicación) y selecciona Iniciar sincronización de aplicaciones.
Instale SS IPTV en los televisores inteligentes Samsung de la serie J
Formato USB Flash Drive en FAT32
Cree en su unidad USB Flash la carpeta denominada userwidget
Descargue el archivo de la aplicación, utilizando el botón de abajo y cópielo (sin extraer) en la carpeta creada.
Inserte la unidad flash USB en el puerto USB del televisor, el proceso de instalación se iniciará automáticamente
Lanzamiento SS IPTV con USB Flash Drive
Esta forma puede no funcionar para algunos dispositivos
Descargue el archivo de la aplicación, mediante el botón de abajo
Crear en la raíz de la unidad USB Flash la carpeta llamada ssiptv
Extraer el archivo en la carpeta creada
Encienda el televisor e inserte una unidad flash USB en ella
Inicie Smart HUB. SS IPTV debería aparecer al final de la lista de aplicaciones (o en la sección Más aplicaciones)
Archivo para Samsung Smart Tv
Re: Simple Smart IPTV (SS IPTV) for LG and Samsung TV
And now this is how to make your SMART TV working with your favorites IPTV playlist
To upload user playlist press
Settings button of the main screen.
Y ahora esto es cómo hacer que su SMART TV funcione con su lista de reproducción de favoritos de IPTV
Para cargar la lista de reproducción de usuario, presione
Configuración de la pantalla principal.
There are two ways to upload user playlist
  1. Uploading by link (external playlists)
    Uploading with non-permanent access code (internal playlists)
    User may have any number of external playlists and only one internal playlist with live channels and one with VoD streams (films).
    To upload playlist by link go to Content section of the app's settings, choose External playlists subsection and click Add button bellow the screen. Enter desired playlist's title and the link of your playlist in corresponding fields and press Save button. The playlist will be available on the Main Screen trhough separeta tile.
    Hay dos maneras de subir la lista de usuarios
    [LIST = 1]
    Subiendo por enlace (listas de reproducción externas)
    Subir con código de acceso no permanente (listas de reproducción internas)
    El usuario puede tener cualquier número de listas de reproducción externas y sólo una lista de reproducción interna con canales en directo y otra con canales de vídeo (películas).
    Para subir lista de reproducción por enlace, vaya a la sección Contenido de la configuración de la aplicación, elija Subtítulos de listas de reproducción externas y haga clic en el botón Añadir debajo de la pantalla. Introduzca el título de la lista de reproducción deseada y el enlace de su lista de reproducción en los campos correspondientes y pulse el botón Guardar. La lista de reproducción estará disponible en la pantalla principal a través del mosaico separeta
    Attantion! The playlist uploads through application server. It means, your link has to be available from external network.
    To upload playlist with non-permanent code go to General subsection of the app's settings and pres Get code button. Non-permanent code can be used only 24 hours (or till new code is generated)
    Atención! La lista de reproducción se carga a través del servidor de aplicaciones. Esto significa que su enlace debe estar disponible desde una red externa.
    Para cargar la lista de reproducción con código no permanente, vaya a la subsección General de la configuración de la aplicación y pres Presione el botón de código. El código no permanente se puede usar sólo 24 horas (o hasta que se genere un código nuevo)
Enter received code here and press Add Device button
Introduzca el código recibido aquí y pulse el botón Añadir dispositivo
When connection was made select playlist file in your PC and upload it by pressing Save button
Internal playlist will be available thourgh tile My playlist on the Main Screen
Cuando se realizó la conexión, seleccione el archivo de lista de reproducción en su PC y cargarlo pulsando el botón Guardar
Lista de reproducción interna estará disponible thourgh tile Mi lista de reproducción en la pantalla principal
New uploaded internal playlist replaces the older one.
Attantion! For internal playlists you may use only m3u playlists, for external playlists m3u, xspf, asx and pls formats are admissible! Playlist file has to be encoded in utf-8 for correct uploading.
All thanks to Eugene Project Leader
La nueva lista de reproducción interna subida sustituye a la anterior.
¡Attantion! Para las listas de reproducción internas sólo puede utilizar listas de reproducción m3u, para las listas de reproducción externas m3u, xspf, asx y los formatos de pls son admisibles! El archivo de lista de reproducción tiene que ser codificado en utf-8 para la carga correcta.
Gracias a Eugene Project Leader
Lo primero que debes de hacer es sincronizar la aplicación de la TV con la web donde se meten las direcciones que es http://ss-iptv.com/en/playlist
Para sincronizar hay un código que te pide dicha web que se coge de la aplicación de la TV en opciones de configuración de dicha aplicación.
Una vez sincronizado ya puedes meter direcciones, tanto individualmente como "a lo bestia" según las listas que postean en el apartado iptv de este foro. Simplemente tienes que crear un fichero con el bloc de notas de Windows, que tenga extensión .m3u y lo guardas como UTF-8.
Una vez creado el fichero de direcciones tienes que ir a la dirección que te comento (http://ss-iptv.com/en/playlist) desde el ordenador y le añades el fichero mediante el botón OPEN que se encuentra en la primera pestaña (my playlist). El botón ADD ITEM es para añadir uno a uno los registros.
En teoría, en cuanto metas el fichero te saldrán todas las direcciones de ese fichero .M3U en la web. Sólo te quedaría darle al botón SAVE y automáticamente te saldrían en la aplicación del TV. Si no salen dale a actualizar en la aplicación de la TV.
Si es para pasar ese fichero a la app de SSIPTV de la TV LG, se hace a través de su dirección web http://ss-iptv.com/en/users/playlist
Ahí tienes que sincronizar la TV con la web mediante un código que te da la app de la TV, entrando en configuración (una vez instalada la app en la TV)
Un saludo
